Corvette LS1 to Tbss
Old Jul 1, 2017 | 02:21 PM
Elky66's Avatar
Default Corvette LS1 to Tbss
I've got a Fly-by-wire Ls1. 2 wire actuator and 6 wire TPS. I've just installed a TBSS with 6 wire throttle actuator.
I haven't wire anything yet because I'm not sure it'll work. The corvette uses a 0-4 TPS and the TBSS uses a 0-5.
I've got a 6 pin to 8pin xlink. I'm thinking I can wire mine to the 8 pin side and let the xlink do it's thing. I'm just reluctant to cut it up.
I can't find any info regarding this swap. Any help would be appreciated.
Thank you.
Old Jul 1, 2017 | 02:28 PM
Did you change manifolds or just throttle bodies? Not specific...
Old Jul 1, 2017 | 02:32 PM
Elky66's Avatar
Sorry, I replaced the intakes. Old one has a 3 bolt TB and the TBSS intake has a 4 bolt. So I'm using the TBSS intake and TB on the LS1
Old Jul 3, 2017 | 09:01 PM
Elky66's Avatar
Ok. Turns out I didn't need the Xlink adater. I converted my wiring to the 6 pin throttle actuator connector. Unfortunately I'm getting a P1515. I think I need to buy a silver bladed throttle body.
