TPS, INJ, and o2 not reading!!!!
Old Jul 15, 2017 | 06:13 PM
banksy08's Avatar
Default TPS, INJ, and o2 not reading!!!!
Just got done a round of mods. abs delete, air pump delete longtube, ory, plugs and wires, rear o2 delete. The car will run. idles just fine, responds to throttle in my garage, have not taken a ride yet. But it will not read tps, o2's, or inj. They all list zero volts. the car runs tho. it runs super rich and is logging some misfires most likely because I have zero fuel trim. I had a the rear 02 tuned out, so then I uploaded the original tune, same thing. After that I installed the factory pcm back in and still everything is reading zero volts. Any ideas? I am completely lost.
Old Jul 16, 2017 | 12:01 PM
Compsystems's Avatar
how are you reading the TPS and inj values? Are you using HP tuners?
If so, it sounds like you dont have your channels set up correctly.
Old Jul 18, 2017 | 10:33 AM
banksy08's Avatar
Channels corrected tps. Inj and o2 still have no readings. I have a buddy coming over with a different interface. I will try that and update.
Old Jul 18, 2017 | 10:11 PM
post a log of your scan
