Spark knock
Old Jul 26, 2017 | 12:14 PM
armour's Avatar
Default Spark knock
hello all. I have a 67 camaro with an LQ4. It has LS6 intake, throttle body and injectors. Mid length headers, stock 317 heads and just installed a Texas speed 224r cam package. Running through a 4l80e trans with stock converter to 9 inch ford with 3.89 gears. My tuner is telling me he is getting spark knock in the higher rpm range which is equating to 309 rwhp on a mustang dyno. Does this number seem low to you guys?? Also, the fuel system is more than adequate. What would cause the ecm to continue to pull spark out up top?? I had 91 octane and he is now replacing with 93. Any advice greatly appreciated for tuning this out.
Old Jul 27, 2017 | 07:53 AM
MaroonMonsterLS1's Avatar
Especially with a swap, start looking for false knock. A loose header, tight header clearance that makes it beat against the floor, etc
Also, as with any knock check for BAD GAS!! Even if it gets plenty of fuel, if its crappy fuel...you'll have crappy results
Lastly, if this is an engine out of a junkyard truck that sat with the hood open in the rain, or got neglected in general, I would pull the intake and inspect the knock sensors and harness themselves. LS valley covers are known to get water in them and ruin the sensor.
I guess I should have answered your question first...yes a 6.0 with a cam making only 309 seems very off to me. Best of luck!
Old Jul 27, 2017 | 08:41 AM
fst100's Avatar
aside from the spark knock, the 317 heads equating to near stock 9.4:1 compression ratio, 4l80, mid-length headers, and 9 inch rear, wouldn't that eat a bit more of the parasitic/drivetrain loss? on top of that through a mustang dyno which reads lower? if adding anywhere between 12-17% would put it around 350-360ish?
Old Jul 27, 2017 | 09:35 AM
I would think with the bolt ons, it should be 325-ish probably 350 tire with the cam
With the cam it should be more.
Can you tell us how much timing is commanded and afr at what RPM?
How much is the KR pulling back out of it?
Old Jul 27, 2017 | 10:00 PM
armour's Avatar
Thanks for the advice guys. The tuner is getting back on it this weekend so hopefully I will have more to report Monday.
Old Jul 28, 2017 | 05:54 AM
fst100's Avatar
the performancetrucks.net forum shows a few stock LQ4s dyno'd 230-240 on a mustang dyno and about 250-260 on a dynojet. stock auto ls1s dyno'd around 280-295ish on a dynojet as perspective.
edit-also are you using the truck pcm that your tuner's using to tune with? if so, I read that the truck tune has a very aggressive torque management and knock retard settings.
Old Jul 28, 2017 | 07:50 AM
I agree but that's 100% stock. Power enrichment tables on these trucks is sooooooo sad. Usually has the delay set to like 5000rpm. Usually just a tune that corrects the power enrichment and tosses a little timing into the mix picks up loads of power.
Old Jul 28, 2017 | 08:28 AM
fst100's Avatar
^true but the OP is still running stock compression ratio. coupled with the 224r cam and his tuner, would add like, what, 35-40whp? again, going back to my question on whether the 9" rear and 4L80 trans and mid-length headers not LT headers would be robbing his horsepower numbers. in the end though, OP, run the car at the track after the spark/knock retards taken care of and see what she runs. hell my old fireturd build ran pretty decent times on stock compression ratio (317 heads) but I never bothered to dyno it.
 Michael S. Palmer
Old Jul 28, 2017 | 09:30 AM
armour's Avatar
It doesn't help that the tuning is being done in 90% humidity. Thanks for the discussion. I appreciate everyone's opinion. Converter and heads are on the wish list or just throw a supercharger on in the future since the compression is so favorable.
Old Jul 28, 2017 | 11:13 AM
Regardless, a dyno is no more than a tuning tool. The number itself really doesn't matter.
Need to find the source of the knock. False or real it needs to be addressed
Old Jul 31, 2017 | 06:46 AM
fst100's Avatar
how much timing are you commanding btw?
Old Jul 31, 2017 | 07:55 PM
armour's Avatar
Had to adjust some settings in abuse mode and the gain on the sensors. 338hp and 349 torque.
Old Aug 2, 2017 | 06:18 AM
fst100's Avatar
mustang dyno I presume? if so, then that's roughly 370-390ish on dynojet which is in line I think. glad the tune helped out.
