HELP!!! No Crank no Start!
Old Jul 31, 2017 | 10:42 PM
WS6GMguy's Avatar
Default HELP!!! No Crank no Start!
Help! ive just ran into a issue with my car.
it was driving just fine. and all of a sudden my car wont crank/ start. no noise or anything... when I get done trying to start it. my gauges will sit there a pulse... wont do anything? does anyone know what this could possibly be?
I'm thinking a ground somewhere?
Old Aug 1, 2017 | 12:27 AM
That would be the first place to check. EVERY ground, and if you're worried any are compromised, go up a wire size or two. You can't have TOO MUCH grounding.
Old Aug 1, 2017 | 12:29 AM
Darth_V8r's Avatar
Moderator
Security light on dash?
Old Aug 1, 2017 | 07:10 AM
WS6GMguy's Avatar
Security light on. But not pulsing
Old Aug 1, 2017 | 11:18 AM
Darth_V8r's Avatar
Moderator
OK. I'd still suggest trying both of these:
1. Disable VATS in the ECU
2. Bypass the key check with the resistor trick
Old Aug 1, 2017 | 11:08 PM
WS6GMguy's Avatar
I think I got it figured out. Its the ground wire from the battery to the block above the starter. I reran it to the front of the pass head. Seems to be alright for now.
