Help with po121 and po300 ......
Old Aug 2, 2017 | 06:32 PM
Justinktm's Avatar
Default Help with po121 and po300 ......
ok I've tried everything now I keep getting the flashing SES light with codes po121 and po300 twice. I've replaced the plugs, plug wires, pcv(hose had hole in it). And just letting it idle it will be fine and then after a few minutes it will start flashing .... I have a loss of power down low when I floor it the car will stay steady for a second or 2 then haul the mail like no ones business. Especially from a dig it will hold it for a second or 2 and then wake up. Any clue what it could be ?
car 00 camaro ls1 with cam,243 heads, ls6 intake 4l80e ,3800 converter, ford 9inch
in the video you can see about 4000 rpm it sounds like I sprayed nitrous or downshifted lol
http://vid102.photobucket.com/albums...pseitvobfl.mp4
Old Aug 3, 2017 | 01:04 AM
tsench's Avatar
your video doesnt work but check your throttle body clean it up for p0300 check for vacuum leak
Old Aug 3, 2017 | 05:53 AM
smokeshow's Avatar
I suppose before asking about diagnostics, I should ask...do you have any scan data while this is happening?
