problem with timing ?
i want to ask you about a timing
the car has l98 6.0
with bolts-on ( air intake , headers , cat-back ) & cam shaft
230/238 625/625 113 trickflow
https://www.trickflow.com/parts/tfs-32603001
the problem is timing
just 20 , the car can't go more than 20 ?
What Spark Plugs, and Gap Setting?
What Octane Fuel, and Brand?
What is your Quench?
What is your Static Compression and Cranking PSI?
Are you using a stock OEM timing set that is set dot-to-dot, or an aftermarket that has been advanced from there?
-tr6 spark plugs
-95 octane
-aftermarket timing belt
