Wideband sensor failing??
as I was driving around forcing 13.0 AFR it would suddenly spike to 22.4 for a bit then back down to14.0, all the while I was steady on the throttle cruising. I have yet to check fuel pressure and change my filter but the car seems to sound the exact same and run ok except now the different wideband reading. Doesn't seem to make a difference when I increase the wot cells of my VE table either.
Any input would be greatly appreciated thank you!
