Using HP tuners timing to reduce power for traction
Old Aug 15, 2017 | 09:58 AM
Bowtie316's Avatar
Originally Posted by AnotherWs6
Lol, he is the one guy who gave you some real advice. This turned into a "you're a fng idiot" thread quickly. I think your logic makes sense. At least it's something to try instead of spending $500 on tires right away.
I generally wouldn't even post this stuff but to be honest, I'm bored, working away from home (and truck) for the next couple weeks and wanted to have a plan of attack when I got back.
Unfortunately, to go much faster, it would take 4 tires not just 2.
Originally Posted by JoeNova
I managed to get an arduino to read the factory ABS sensors on my C4 corvette.
With a tiny bit of math, it will force a table switch on microsquirt and change to a completely different timing table for a super quick and easy $14 timing based traction control.
Having it do the exact same thing with the IAT switch trick on a stock PCM would be cake, assuming the truck has at least rear ABS sensors, and either front ABS sensors or a working electric speedo signal somewhere.
Wow, now were talking. While I wasn't really thinking of traction control, this would be badass. I don't have any ABS sensors (must be early c4) but I could probably rig something up eventually. Thanks for the input.
Old Aug 15, 2017 | 10:36 AM
JoeNova's Avatar
Restricted User
Look into IAT timing retard. You wire your IAT signal through a 5-pin relay so that its passing through the normally closed circuit and acts as normal. Activating the relay disconnects the IAT signal and forced the ECU to read the coldest columns of the IAT timing tables, where you can tell it to pull as much timing as you wish.
Activating the relay is the hard part. Most guys use a momentary button on the shifter and use it to cut timing to negative to spool a turbo on the line. The one in my Nova is activated with the brake pedal for the same reason. If you had ABS sensors, you could use an arduino to read the speeds and activate the relay if it sees the rear tires spinning faster than the fronts.
Or you could just use HPT and pull timing out of the mid range to prevent spinning, but it will slow you down.
Old Aug 15, 2017 | 10:37 AM
AnotherWs6's Avatar
So you're saying it works like conventional traction control? When it detects higher wheel speed in the rear it switches to a different timing table and then switches back once speeds are close again? How quickly does it react back and forth and how effective has it been?
Old Aug 15, 2017 | 10:43 AM
JoeNova's Avatar
Restricted User
It reads and averages rear wheel speeds, and then reads and averages front wheel speeds. If the rear speed is greater than or equal to 1.15x the fronts, it activates a relay on the wire microsquirt uses for table switching, and it pulls timing depending on RPM/KpA. Anything over 100 kpa gets 10 degrees knocks out so it doesn't kill me. Anything below 4000 RPM only gets 5 degrees pulled. I haven't fine tuned it, but it works fine. I stop spinning pretty quickly. I'll have to adjust just how much timing it pulled to keep it from switching so rapidly and find a nice medium.
I haven't spent a lot of time seeing how fast it reacts. Once it spins, it reacts before I'm able to blow the tires off, and seems to stay in reduced timing mode until the spinning stops completely. The only issue is that it will stop spinning, add timing and start spinning again. It almost feels like the rear ABS is kicking in and I get a slight shudder.
Old Aug 15, 2017 | 12:17 PM
kingtal0n's Avatar
humans remedied traction through power reduction with drive by wire solutions. Doing it with other methods is dated and out of popularity, since even without traction issues the linearity of cable driven throttle bodies does not complement the curve-like onset of power from a given random engine in a majority of situations. Many changes to an engine may result with reduced or altered power curves with DBW doing it more elegantly and efficiently, when necessary than most if not all other methods.
imo, bottom line is: If I had a car that needed guaranteed traction for $$$ races it needs to be DBW proper.
Old Aug 15, 2017 | 12:25 PM
Bowtie316's Avatar
How difficult is the Arduino programming part? That might be the deal breaker for me, I have zero coding experience.
Oh my, you use more words than anyone I know, to explain something so simple.
Old Aug 15, 2017 | 12:33 PM
JoeNova's Avatar
Restricted User
There is not one SINGLE person that enjoys having him here. He's a plague that spits out useless "knowledge" yet he has absolutely nothing to show for it. No merits, no accomplishments, not even a completed LS swap. Nothing.
Old Aug 15, 2017 | 02:06 PM
SLOW SEDAN's Avatar
Agree, funny how people that haven't done anything have so much to say. Although he did make me laugh with his last comment... so its free entertainment. Him thinking fast cars with traction control need to have DBW TB is hilarious, he obviously hasn't seen a race car with a Davis box.
Old Aug 15, 2017 | 06:18 PM
kingtal0n's Avatar
I don't get to play with any cool toys, or see any race cars. This isn't a site for people with race cars, or even that own cars. you can be here and never have owned a car before, it isn't a pre-req. I am poor homeless person with no property of my own and you can only bash me for it?? Thanks
what would you consider an accomplishment? tie your shoe laces? So I can be sure to become important in your eyes. because it means sooooo much to me.
Old Aug 15, 2017 | 10:22 PM
No, it's about backing up theory with actual knowledge of how things work in real life. A homeless person can hang around race cars, ask questions, see how it ACTUALLY works in real life without owning it. So knock off the pity-party-tirade. Some of your posts on these forums make good sense, then other times you come out of left field with theoretical BS that has no real connection with reality. Like the above about DBW that is proven all day to be BS.
Old Aug 15, 2017 | 11:00 PM
subeone's Avatar
just reduce timing, back off about 8-10 degrees.. dont know what else to say. Unless you have a standalone computer, the factory pcm cant do much in regards to traction.
Old Aug 16, 2017 | 08:31 AM
  #32
Bowtie316's Avatar
Thinking about it some more, if it just ran like a stock 4.8 it would probably be faster.
I think I will limit total timing to 20 degrees, leave idle timing where it's at, and make a straight line in between.
I'll give it a go on the street and see what it does. I know it is easy to kill power, but I'm just going to have to play with killing power without killing response.
Old Aug 16, 2017 | 09:10 AM
  #33
etijsma's Avatar
Because you basically asked the tuning equivalent to;
-Who has ran a wider tire and gained traction?
-Who has went boost and gained power?
-Who has removed parts and lost weight?
-Who has turned on their heater and felt warm air?
So yes, its a little hard for me to grasp the purpose of this post.
I have timing by gear setup on the stock PCM. Works like a charm running less timing in first gear to gain traction with a manual boost controller. Hundreds, if not THOUSANDS of racers pull timing in first gear to gain traction. Its common practice.
Joe,
Do you have a write up on how you did this?
Old Aug 16, 2017 | 09:26 AM
  #34
JoeNova's Avatar
Restricted User
I have a video made with HPTuners setup as a demonstration. I'll post it up hopefully in the next couple of weeks as I'm trying to get the boost by gear video working as well.
Keep an eye out here for it:
https://www.youtube.com/channel/UCJ6...aKBaK3shsXkJmw
Old Aug 16, 2017 | 09:48 AM
  #35
01ssreda4's Avatar
Old Aug 16, 2017 | 11:35 AM
  #36
AnotherWs6's Avatar
He's a plague. He's like open herpes sores on top of a lump of cancer. His parents should have been sterilized.
Think he's ever gotten laid?
Old Aug 20, 2017 | 08:26 PM
  #37
kingtal0n's Avatar
I would do surgery to save anyone's life
no matter what they said
and give them the highest medical treatment possibly possible
nobody would move faster to save life
Old Aug 20, 2017 | 09:10 PM
  #38
BUT being you're not a surgeon, you saying that is VERY scary....
Old Aug 21, 2017 | 06:58 AM
  #39
JoeNova's Avatar
Restricted User
Jordan, nobody here ever said you were a bad person. And its obvious you're not stupid. You're just unbearable.
Old Aug 21, 2017 | 08:06 AM
  #40
01ssreda4's Avatar
Posts like this is what makes people not like you. Its some **** you dreamed up in your head. Its THE perfect theory, but its not practical! The average guy isnt gonna swap his car to DBW (if it was cable stock), there is too much bullshit involved. On the other side of the coin, a real racer, will have a proper PCM (likely aftermarket) to control a ton of functions including traction control but i guarantee they arent running no drive by wire bullshit and it probably works off wheel speed sensors and altering timing (if i could guess). So by your above post, you mean to tell us you know more about going fast and traction control then the guys that do it everyday. You're a silly little boy who reads books and never actually turns wrenches or even hangs around with people who turn wrenches. That's why you catch so much ****
