New to hptuners
You just need a 12v charger that plugs into a wall outlet, an OBD-II port, and a spare Blue PCM connector. You can buy all of that stuff new from ebay for $40, or go to the junkyard for the ECU connector/OBD port and use whatever charger you have laying around. If you have a spare car battery, that works too.
After I turned off VAT's and disabled the Evap, O2's and corrected the gearing and tire diameter I decided to mount all that junk in a box.
BTW, I have only had HPT a few weeks but there is plenty of help available.
