New motor, now computer problems???
If it doesn't have 12v then you're right, you got to back up to figure out why.
If it DOES have 12v, then why isn't it cranking the engine?....
bad ground back to battery?
bad positive connection from battery?
engine locked up? Can you turn it by hand?
So you pull the key out of the ignition and the dash still stays on?
Just reread your first post. Just throwing things out there...any damage done to the steering column during R&R?
Somebody here probably knows what module lights the dash in a 2005.
Earlier you said you found a ground wire smashed. Had you applied voltage/tried to start before or after you found that?
Thank you all for all your help. You were all awesome! This is a great forum and i'm sure I will be asking many more questions. I still have to tune it. It doesn't idle very well, but will figure that out later. Just glad to have it started. And then I am building another LS to put into my 66 impala. I can't thank you all enough.
