maf table on 3bar
Old Aug 30, 2017 | 09:49 PM
Dylanplace's Avatar
Default maf table on 3bar
why is it that in all my boosted engines I have to modify the first box is the maf table to get the engine to start? I set it to 10.00. just seems odd on 3 bar. and shoulkd I be changing them all? is there a way to scale the whole table?
Old Aug 30, 2017 | 10:12 PM
Darth_V8r's Avatar
Moderator
It's a quirk in the controller. The maf curve is used until the maf fails. With no maf signal, the lowest cell is referenced.
This is true even on a custom SD OS. As long as you're using a OE ECU the maf has to fail out before it runs pure SD.
Putting 10 in that cell just gives you fuel until the maf fails. I always use 15, because on cold start there's a lot more air demand vs warm idle.
Old Aug 31, 2017 | 11:51 AM
Dylanplace's Avatar
thank you. I'm just trying to get a better understanding of why I have to do the things I do
Old Sep 3, 2017 | 03:37 PM
rpturbo's Avatar
Good info here. I did not know this! Thanks IN advance!
