Issues with 90mm TB and Xlink...help!
hello, I'm having issues trying to get a 90mm TB with Xlink to work with my LSA supercharger swap....I'll give you guys the background and specs...I have a 2005 LQ4 stroked and bored to a 408, with LS9 cam, 317 heads, LSA supercharger, truck harness, blue/green pcm, truck tac module, c5 corvette pedal, tuned with EFI live. I drove the truck earlier this year without the blower installed, and had absolutely no issues with the stock 78mm TB. Did the blower swap, added X link, and a gold blade LS3 TB. I continue to get P1516, P2108, U0107 DTC's often. The tuner is saying the issue is with X link, or TB or TAC module or bad harness, mismatched pedal. I have spent countless hours searching forums, testing all components such as harness, pedal, etc...I can't find anything wrong! The TB opens and closes as it should, nice and smooth. I have replaced TAC module, and even tried a 87mm truck TB, I still continue to get DTC's. I have read multiple post of people getting the X link to work perfectly....what am I or the tuner missing here? I'm close to buying 4 bolt to 3 bolt TB adapter for the 78mm TB, and extending the harness. Can anybody shed some light on how they get this X link to work??? Could it be something else not related to TB??
