need help 4l80 to 4l70 swap
I have an HPtuner. but I am a total newbie to it.
So now that I have rewired the wiring harness for the 4l70. Is there any tuning I need to do for the 4L70 to work with the LQ4 computer. Can I just use a bin.file for a car or truck that came with a 6.0 litre motor and a 4l60 transmission.
any help on this subject would be greatly appreciated
With a regular 6.0 the 60e or 70e will bolt right up with a normal crank. Thin with a 80e u add a spacer and flat crank to install it. But with a long crank 6.0 a spacer is not needed like with a normal 6.0.
So with the longer crank would make converter to crank engagement way to tight. U could probably get around this with a special built converter.
http://lt1swap.com/4l60e_4l80e_harness.htm
Thank you for your help at least now I can get going in the right direction.
