96 3.8 pcm pinout
Old Sep 16, 2017 | 01:20 PM
70chevrolet's Avatar
Default 96 3.8 pcm pinout
Im chasing egr pintle position code. tests good at idle but problem is intermittant. been throught the entire system and have it narrowed to bad pcm or bad wiring. Def not cabon or vacuum on this one, im assuming its a corroded wire that tests good at idle. Valve is delphi brand new. On the 3.8 the egr harnes loops behind the engine preventing me from visual so im just going to run all new.. Anyone have a hookup for the pinout?
1996 camaro rs 3.8 conv.
1000 please and a million thanks.
six banger..
Old Sep 16, 2017 | 03:22 PM
to answer my own question.. does this look right?
its listed under 96 camaro however the document says
"CENTRUY, GRAND PRIX , IMPALA, INTREIGUE, LUMINA, MONTE CARLO, REGAL 2001-2005"
http://www.autozone.com/repairguides...96b43f80cb3c03
Old Sep 16, 2017 | 04:25 PM
2xLS1's Avatar
Old Sep 16, 2017 | 06:22 PM
Hey thanks for posting that. That looks like exactly what i need. Just to clarify. Based on that diagram, It looks like the ground and the 5v rev signal are common with the map and tps. Can j just run a jumper from those sensors rather than new wire all the way to the pcm? Also with respect to the brown wire for pintle position sensor, there are multiple browns at the pcm. It is labeled number 65 in the diagram, but i dont see numbering on the pcm itself. How would i ascertain 65 at the pcm?
thanks again
