VSS speedometer wiring
Old Oct 19, 2017 | 06:04 AM
brett14's Avatar
Default VSS speedometer wiring
Trying to wire up my speedometer a little confused. I have my two wires coming out of my t-56 to my pcm. I got 1 wire coming from the PCM to the speedometer.
First of all is that correct?
and do I need a Dakota digital speedometer signal or does the PCM convert it into the correct signal for the speedometer?
Old Oct 19, 2017 | 06:37 AM
JoeNova's Avatar
Restricted User
The PCM does the work of converting it to a proper speedo signal and sending it to the speedometer. VSS wires will always go to the computer.
