Reduce timing to tune VE table?
Old Oct 29, 2017 | 05:25 PM
TXjeepTJ's Avatar
Default Reduce timing to tune VE table?
I知 having a hell of a time trying to tune my turbo LQ4 on the street, I can only go WOT for a couple of seconds because of the power output and the conditions of where I知 tuning..
could I drop the timing down to reduce the power to dial in my VE table??
Old Oct 30, 2017 | 10:50 AM
MontecarloDrag's Avatar
Reduce the timing to a safe level but not too much or you will cause hesitation or misfires which will skew your VE.
I normally tune VE first with timing dialed back to a very safe level. Once fuel is dialed the PCM will see the correct g/sec and reference the final timing cells on the high octane table. Then you adjust timing to those cells to the correct value.
Then do a few final WOT passes to recheck VE and fine tune if needed.
To tune VE, a long pull in 3rd is enough for each adjustment.
