Holley HP or Dominator?
Old Nov 3, 2017 | 11:57 AM
Audioslave1's Avatar
Default Holley HP or Dominator?
Im planing a 1000hp 240sx LS1 408 swap with a pt88 to drag race. Ive been confused about getting big 120-160lb injectors to work with the ecu and then I found Holley efi's. Now this car is gonna mostly be a drag car but i definitely want to drive this on the street and ruin ricer feelings, that being said which efi should i go with? This build is the most expensive build I've done to date and money is a huge deciding factor. I can get the HP plus ALL wiring it needs for $1800, but the dominator is like $2k for just the ecu....and i can't find ANY dominator packages that are just the ecu and wiring, all the kits are almost 5k because they include things i don't need like fuel injectors. So thats why i want to go with the HP. But at the same time i know you pay for what you get and i don't wanna buy an efi just to switch it out to another down the road. Im not getting hardcore into track days,its all just fun to me, so I don't really care about all the data log features the dominator has. So what I'm asking is will the HP be plenty for my 1000hp boosted build?
Old Nov 3, 2017 | 06:25 PM
LSX Power Tuning's Avatar
Give us a call on Monday and let us properly spec out you a Holley EFI system. We sell dominators 10 to 1 to hp's but that doesnt mean you dont need a hp. Each setup and persons needs are different.
Old Nov 3, 2017 | 06:33 PM
fastlt1's Avatar
Does either auto tune timing maps
Old Nov 4, 2017 | 12:29 AM
No.
There is no such thing as an auto tuning efi system, its a very miss used term with efi systems.
Old Nov 4, 2017 | 01:28 AM
LLLosingit's Avatar
Look at the Holley Terminator Kits, I just bought - Holley EFI Mpfi Kits, Terminator Mpfi, Ls2/3 & Late Truck - With Trans, Part #550-612 for $2,311.16 from http://www.tickwholesale.com/holley-...-part-550-612/
You have to join to see that price, If you haven't seen the Terminator Kits before there are several. Some use the HP ecu and some use the Dominator ecu. Since it's a kit it will save you some money. Choose the kit that best fits your needs.
Why spend $1990 for the ECU alone when for $300 more you get the Dominator ecu and LS1 or LS3 harness plus power harness/Injector harness/trans harness or DBW Harness plus one 02-sensor and a 3 1/2" screen.
Buy the Dominator...If not you'll wish you had. If your stuck on the HP ecu version of the Terminator kits run about $1500 to $1700 (depending on kit) and include almost everything you need.
Edit: Tickwholesale price for the Holley EFI Components, Kit, Fuel Injector 160Pph, 8 Pack, Part #522-168 is $524.76
