CKP Sensor Position
Old Nov 8, 2017 | 11:55 AM
BBPanel's Avatar
Veteran: Marine Corps
Default CKP Sensor Position
Does the crank reluctor need to be centered on the sensor? I'm doing a custom build using the Gen VI BBC timing cover and the 24x reluctor is slightly off center - don't know if that is an issue or not. Will be using a 0411 PCM. Thanks. -Bob
Old Nov 9, 2017 | 11:14 AM
pantera_efi's Avatar
Default CS Position Mount
Hi Panel, yes and the dual element sensor is directional.
I manufacture a 24-1 TW for use under a BBC Gen-V+ front cover, also a 36-1.
Lance
