Ws6 ecu
Old Nov 14, 2017 | 10:29 PM
Patton007's Avatar
Default Ws6 ecu
So I got an LS1 out of a WS6 to swap into my 240sx but I don't have the ECU for it and so I have two questions. 1. Can I use a early 2000's ECU with this motor if it is out of a camaro or will it not run right? 2. Is it true that the LS1 out of the WS6 has an LS6 crank shaft and heads? TIA
Old Nov 14, 2017 | 10:54 PM
What year was the WS6? 2001-2002 LS1's came with the LS6 intake manifold, but LS6 heads (243's) never got put on LS1's. I believe the cranks are the same, so no difference there.
Old Nov 14, 2017 | 11:01 PM
Patton007's Avatar
the guy I bought it from said it was out of his 2000 WS6. Ok thanks for the info I didn't know that
Old Nov 15, 2017 | 08:41 AM
LSX Power Tuning's Avatar
99-02 f body pcm's are interchangeable, just the calibration is different which can be changed. We like to you 2002 OS 12212156 as starting point for tunes on swaps.
