LFX swap questions
Hi all!I've started a 2015 LFX/6l50 swap into a 72 Chevy p/u.
I'm working on converting the harness for stand alone operation and 2WD operation (was originally a 4x4).
Have gotten most documentation from the ACDelco TDS website, this forum, and several build logs on the Miataturbo.net forum.
I have created a Pinout spread sheet based on AkaNovaman's but this system uses the E92 computer, so some pins are in different locations.
Questions:
Is the ambient air temp sensor used in engine function or can it be deleted. Pretty sure these duties are handled by MAF.
Vehicle speed was provided by a sensor on the transfer case. Connector B14 to the x2 connector on the ecm. 2wd applications get this data from the TEHCM.
The information I have shows 2WD applications using HiSpeed Lan to get the information from the TEHCM. Can anyone confirm this?
I have the BCM, and am considering using it because I would like to facilitate use of the factory shifter (tap/up, tap/down). BCM will also allow use of the in tank pump module to control pressure and fuel level functions.
BCM will provide the tach information using the LAN, or I can get a signal converter....
The loaded question is? Any big reasons not to go with using the Hi Speed LAN this approach.
Thanks in advance for any information or advice.
Tom
Yellow indicates circuits I plan to delete, other colors are area where I have questions. I haven't decided if I will keep the secondary O2 Sensors. Also they seem to skip wiring one sensor on the O2 system (it may just be me).
Thanks
I'm considering this swap for my 66 C10. I really like the idea of a fuel efficient, high power DI V6. I really want to do a manual tho, which will of course make everything 10X harder.
Srsly tho - need pics!
Haven't done much to refine the tune yet, 320 hp in a 2200 Lb Samurai is a bit excessive as is!
Cheers!
