Any issues? New motor old PCM
or you can use this. Might I suggest swapping the cam as well since the LM7 had the weakest cam ever put in an LS.
Just look at the crank sensor color. If its black its a 24. Grey is 58. Your ecm shouldnt have any issues running it. The knock sensors may be on the side of the block tho. If it is thin u can buy a converion harness. Also limgenfelter sells a 58 to 24 conversion box. So it can be done either way if u want.
