ECM crank request wire
Old Nov 26, 2017 | 07:20 PM
Skydawg's Avatar
Default ECM crank request wire
E67 ECM has a pin for crank request, which I expect energizes the starter solenoid for about 3 seconds without requiring holding the key, or until engine starts. I can not find a schematic that shows if this wire is grounded or energized to activate. Anyone?
Old Nov 27, 2017 | 12:43 PM
EFIHARNESS's Avatar
What pin # are you talking about. There are different configs depending on app. Steve
Old Nov 27, 2017 | 01:20 PM
Skydawg's Avatar
its J1-1 on the MEFI 5 version of the ECM, not sure what it is on other versions of the E67. I think all should act the same.....is it positive or ground typically from key switch for ECM to trigger starter?
Old Nov 27, 2017 | 10:42 PM
EFIHARNESS's Avatar
What are you trying to do with this system. That pin can be set in the software. It usually comes from the crank position on the ign switch.
Pin J1-26 is the hs output that goes to the starter control relay. Steve
