Oxygen Sensors
Old Nov 28, 2017 | 06:49 PM
71ChevyLS's Avatar
Default Oxygen Sensors
I have a 1971 Chevy K10 pickup with a lq4 6.0, out of a 2002 Chevy 1500hd. I’m looking for Oxygen sensors to buy. I got some O2 sensors from a 6.0 in the junkyard but not the same year. I have a wiring diagram to wire in the 2002 oxygen sensors. I’m looking for 2002 Chevy 1500HD 6.0 front o2 sensors. What is the best option for sensors? Aftermarket? Or used from a website? Thanks
Old Nov 28, 2017 | 08:32 PM
Honestly, you would be best served with new sensors. There are other places to cheap out; sensors aren't one of them. Rock Auto can be your friend here....
Old Nov 29, 2017 | 08:32 AM
pantera_efi's Avatar
Default WorldPac Lambda Sensors
Hi LS, I supply WorldPac with Lambda sensors.
I like the NTK "hot start" sensor as best. (2x life)
The wire color =
Heater as white (2x)
Signal ground as Gray
Signal output as Black
I buy my sensors from Wixom
Lance
Old Jan 27, 2018 | 10:35 AM
93 coupe's Avatar
71chevyls, can you share your O2 wiring diagram, I am having some issues with the same swap. Thanks
