What is Code P0120
Old Jul 1, 2004 | 10:41 PM
SS125's Avatar
Default What is Code P0120
What does a code P0120 mean. The diagnostic says "Throttle Position Sensor Performance"
Old Jul 4, 2004 | 01:45 PM
SS125's Avatar
Nobody can tell me what this means?
Old Jul 6, 2004 | 12:39 PM
redz_02's Avatar
if you have an autozone near by they can check codes for you.
Old Jul 7, 2004 | 03:29 PM
xaon's Avatar
He's already got the code. I too am currently throwing the same code on my Formula. I was throwing another code (TPS Malfunction) but I swapped out my TPS sensor and that one has not resurfaced so far.
Has nobody else ran into this problem?
Old Jul 7, 2004 | 03:48 PM
MyLS1Hauls's Avatar
The "TPS Performance" code is set when the TPS has an erratic output and/or the PCM thinks the TPS output should be something other than what it is...i.e motor is running 6000 rpm and the TPS is saying 10%. I'd be willing to bet you've got a sensor on its way out. I'll have to double check it in my service manual to see for sure what the criteria is for setting the code.
