Help!
Old Dec 24, 2017 | 10:26 AM
camarovon's Avatar
Default Help!
I'm trying to figure out why my 01 408 camaro hp peaks at 5800, 244/248 cam,fast 102/102, tfs 245 heads, auto a4 vig 3800,9inch 411 gears!
Old Dec 25, 2017 | 04:06 AM
camarovon's Avatar
No help !wow
Old Dec 25, 2017 | 07:03 AM
baronsmith98's Avatar
Post a tune file, and a log file. What is your afr? Timing? What is your valvetrain setup?
Old Dec 25, 2017 | 09:33 AM
dw456post's Avatar
Originally Posted by camarovon
No help !wow
You must have forgotten this is a big holiday. Most people are not even reading this site.
Cam design could be the culprit. I had a cam that peaked around 5000 rpm, changed cam to one that was designed to peak around 7000. Maybe ask you cam guy?
Old Dec 25, 2017 | 11:00 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
The problem really could be anything, based on the utter lack of info you provided, but I will take a stab at it. I'm betting your timing flatlines after peak torque.
Old Dec 27, 2017 | 02:18 PM
pantera_efi's Avatar
Default Dyno Report
Hi Ovon, the information you provided would state this is a good report, 600+ HP.
Lance
