Tuner Questions
1. Which is the best one on the market?
2. Do these tuners work, like the H&S minimaxx I have in my powerstroke? (i.e. clear DTC codes, recalibrate for rims/tires, cam change, rear diff change, turning off airbag light). Or do I need to take it to an actual tuner to correct the above stated?
Here's my situation:
2001 Camaro SS M6
ASR light goes on and off, I believe the sensor in the rear needs to be replaced, but does it need to be calibrated for putting 4.10 gears in?
Airbag light is on, Code is for "option configuration, can a tuner correct this?
CEL is on for maf and tps high/low. MAF because its SD tuned, and TPS high/low because of the cam, TPS % needs to be adjusted.
Any help is appreciated.
