Speed density tuning questions
My car starts fine in 20 degree weather. I would never actually drive it in those temps, but I did want to see if it would start and idle ok in those temps. Initially it would pop right off and rpm's would jump right up to 1200 then die. I added time to the initial start up air flow and gave it the base running air flow it wanted in those colder temps that I hadn't been able to log previously then it was fine. I think it's normal to run rich for a little bit at start up in those cold temps then it drops down to 15.2 AFR and idles nice at 825 rpm.
This is my first ever attempt at doing my own tuning. It's a small miracle I haven't broke this motor yet LOL. I feel like I've learned a lot already and hopefully by the time I buy a forged motor I'll be a decent tuner.
Despite your stated air to fuel ratio numbers, a "perfectly white" spark plug porcelain would indicate a quite lean condition. My guess would be that your cylinder head temperatures are somewhat hot and I'd be a lot more comfortable with some brown tan color on my spark plug internal porcelain . . . run it richer . . . and cooler.
Rick
Rick
try asking your trans to shift faster with less torque management and more line pressure. also you can unlock your converter fulltime which will help absorb a small amount of hurt you're giving your trans
however if its flared lots, good chance its toast
To go back to MAF:
1. re-enable LTFT's
2. re-enable MAF set fail freq back to stock
3. re-enable DFCO <helps with mileage too
4. re-enable COT.... if you still have those...
Going back to closed loop isn't a bad idea for the street. Helps the PCM in a lot of ways run the car more efficient.
If you have a big cam, you can still have MAF enabled and do a SD idle setup. Just go to your PE settings, set the TPS enable to 0 through about 1200 rpm, and set the map enable under your normal idle map, i.e. 50 or 60 ish for a big cam. Then set your PE eq ratio to 1.0. Then your car will idle in PE mode, at stoich or whatever you tell it to (SD mode, STFT's disabled). As soon as you go above 1200 or whatever you set it to it will go back to using MAF numbers and STFT's.
I'm not getting any KR any where now and really feel like I should put some more timing to it, but I'll leave it alone until I can get on the track or dyno.
I got on it as much as I could with no 4 to 2 down shifts and lifting from wot before the shift point. I tested several "tip in" points no KR. I also went out on the highway in both 55 and 70 mph zones for a while to check cruise AFR. It was pretty much stoich in those areas and I decided to leave it that way rather than tune for a lean cruise. My reason is some of those same cells are where I was getting KR previously on tip in and a tip in from those cells seems more responsive at 14.7 than it was at mid 15 AFR.
After I was done I pulled #7 plug and it looks great no detonation. My timing drops all the way down to 9 in boost then ramps back up to 14 at 6400. Fuel is 93 octane with a can of heet in every 5 gallon jug before I put it in the car. I already want to put a smaller pulley on the procharger and add meth, but I'm going to hold of for now.
I decided to go ahead and get a new converter when I do the transmission. Yank recommended the PAS3400 so I'll probably go with that. Track opens in April so I'll get the trans done in March and should be ready to test to see if it's really making the power I think it is.
When the MAF is enabled, though, then the PCM uses actual metered air to calculate g/cyl, and make fueling adjustments. On some PCMs the computer uses both to do this, like gen IVs where VE and MAF are biased based on RPM because VE is more accurate at lower RPM, whereas the opposite is true at higher RPM, so it biases MAF. The last gen IV I tuned I just disabled VE and tuned it for 100% MAF. This is a pretty common practice.
There is a silver lining though, while in SD you can still usually enable the STFT's so your O2's can help with making adjustments for fuel. The air calc still won't change though, and if it's off enough then the O2's will actually be more of a pain than a help.
So what it sounds like on your tune is VE was tuned at lower IAT temperatures. Fuel doesn't mix as well into hot air, and there is less air to mix with (hotter air is less dense, but has higher pressure because it's contained). Couple this with the increased chamber pressure due to heat equals more fuel is required to cool it down. GM accounts for this with ECT. The colder the engine, the more fuel. Also, the hotter the ECT, the more fuel. At operating temp, stoich is the target. Just have a look at a stock OL EQ table to see what I mean.
Moral of the story is heat has a huge effect on fuel, but GM assumes MAF will be used to calculate airmass. That is thier "correction" for heatsoak. What that means for us SD guys is try and tune the VE at temps that the car will most likely see, I.e. normal operating conditions. Either that, or account for it by tuning your idle cells when IAT is very high. This will cause the exact opposite of what you were seeing, as in a lean condition as soon as it starts cooling down, but creep back to stoich as it heats up.
I dealt with that for a while trying to find a happy medium. Without a WB it wouldn't be something you'd notice at all. But when you are a perfectionist, and you can see your afr all out of wack suddenly, even though the car runs great, you tend to look into more, and make unnecessary adjustments. A good friend of mine and I were discussing this recently because he has the exact same issue. We decided that perhaps a "winter tune" and "summer tune" might be the answer. I can say my summer VE table is definitely different than my current one.
Another interesting point is as the IAT goes higher, the PCM will pull timing. Might not seem like a big issue at first, but with aftermarket cams and mods, timing has a bigger effect the actual vacuum the engine is pulling. Less timing, less vacuum which means slower air. As air velocity decreases, pressure increases. So wouldn't it be possible to get into another cell on your injector flow rate? Keep in mind, on that table, more vacuum equates to less fuel. As the MAP kpa goes up, (closer to baro = less vacuum) the flow rate is increased. This would have the greatest effect at idle.
I try and learn something new everyday. This is a neat topic and there is a ton to learn about it. I haven't even got into the effects of heat and compression, and it's already pretty complicated.
