Switch to a throttle cable? Need help
Old Feb 23, 2018 | 12:17 AM
Steven Woods's Avatar
Default Switch to a throttle cable? Need help
i have a 2006 silverado with a 5.3 that has electric throttle. I wanted to know if I could change the fly by wire to a cable set up. If I put a different stock pedal with throttle cable what do i have to do to make everything correct again . Is this possible? I do have a hp tuner if that helps. Or do I need different position sensors . I would like cruise control to work as well
Old Feb 23, 2018 | 01:07 AM
codyvette's Avatar
I don't think it would be easy at all. Drive by cable ECM's run a different operating system and it would probably require a lot of rewiring and a different ECM.
Old Feb 23, 2018 | 01:33 AM
ok thanks thats kinda what I figured.
Old Feb 23, 2018 | 10:06 AM
With a Gen IV ECM it's impossible. It has to know the throttle position via the wire connection
Old Feb 23, 2018 | 12:05 PM
LSX Power Tuning's Avatar
2006 is gen 3 pcm. You can convert a 2006 to drive by cable but it requires adding wires for tps and iac and also changing the pcm. Not worth it at all IMO. We have tuned a couple that have been converted.
Old Feb 24, 2018 | 10:56 AM
brandon6.0's Avatar
^^^just as stated. U gotta make sure u have the drivers for tps and iac in the pcm. Thin flash it with a van OS. I just done one of these conversions last week.
Old Feb 25, 2018 | 08:05 AM
01ssreda4's Avatar
Why specifically do you say it isnt worth it?
Old Feb 25, 2018 | 06:17 PM
rpturbo's Avatar
I think the question is, why do you want to change it? Properly tuned, you should not notice any difference at all between the 2.
 Michael S. Palmer
Old Feb 25, 2018 | 06:57 PM
Correct, why go through the trouble?
Old Feb 26, 2018 | 07:49 AM
toplessHO's Avatar
not to derail but what if the same drivetrain going into a cable driven host.
wiring harness,PCM and TB can be changed before install?
Old Feb 26, 2018 | 11:23 AM
codyvette's Avatar
It can be done, yes. If I have the petal that goes with DBW, that's the route I go. I could see in the instance that it is missing, switching so you don't have to source a petal.
Old Feb 26, 2018 | 05:44 PM
toplessHO's Avatar
yes but that's also opening up a can of worms for the CC
Old Feb 27, 2018 | 08:53 PM
brandon6.0's Avatar
I converted the harness bc we swapped a 5.3 into a v6 silverado. It was just easier to keep the cable operated stuff.
