What to expect from tune after lowering compression
The performance changes while doing the rebuild have been going from 10.5:1 compression to 8.1:1 compression through putting dished pistons and 317 heads that are not ported. I will be swapping over the pac 1218 springs over to the 317 heads. Also my prior tune was done at 6000ft ASL and I'm now at 1000 ft ASL.
My question is from a tuning perspective am I going to need a base map to be able to break in my motor for 500 miles before taking it in to get dynotuned? Would you expect it to idle be driveable or will it be pig rich from the lowered timing and added fuel for the higher compression tune that was previously getting run? Thanks.
go for a gentle drive around the block and look at what the STFT do to begin with. adding or subtracting that percentage is a good place to start.
