11.0 afr @ cruise
Old Mar 7, 2018 | 01:58 AM
Tappethead60's Avatar
Default 11.0 afr @ cruise
Hi,I have a 6.0 L77 M6 which has suddenly statred running very rich no matter what tune I flash into it. E38 pcm. I replaced the O2 sensors today thinking they were contaminated but it actually fouled a plug when I went to drive off. It does have a cam in it but the afr's just seem to be getting worse as it is washing the bores & starting to use oil when it warms up. Any ideas? I am using EFI LIVE.
Old Mar 7, 2018 | 03:47 AM
Thumbs up
Never mind, I found the problem.
Old Mar 7, 2018 | 05:48 AM
Old Geezer's Avatar
Lightbulb And...
What was it?
Old Mar 8, 2018 | 02:40 AM
Hey, when I did a read it showed that my tune was staying in open loop. I had no feedback from the O2 sensors because I had loaded a calibration to the pcm to do swingtans vve dial in.I must have saved over the original file after one too many beers I guess.Flashed a tune after checking that closed loop hadn't been disabled & I got my 14.6 at cruise back.Time for an oil change & filter inspection I think.
