Fast 92 & Ls2 TB on Ls6 limp mode HELP
Old Mar 14, 2018 | 04:59 PM
Magnoman's Avatar
Default Fast 92 & Ls2 TB on Ls6 limp mode HELP
I installed Fast 92& L2 TB on Ls6 limp mode HELP ..
First try had a (gold blade) LS2 TB car ran great pulled like train @ WOT get limp mode .
Was told I need (Sliver) LS2 TB and would cure problem . Its worse with Silver Blade TB TPS gets to 42% and Limp mode code 1220 .
I do have HP tuners changed Scalar to 192 tired 182 same issue . tried changing few TAC tables nothing helps
Tested wire harness adaptor seems fine . Did ohm test on TB that seems ok also .
Baffled ..
Old Mar 15, 2018 | 10:06 AM
Luke19901's Avatar
following for info.
I would like to know how to make a LS2 silver blade work in the place of a gold blade LS3 on E38
Old Mar 16, 2018 | 09:22 AM
LSX Power Tuning's Avatar
Without posting your tune I doubt anyone can help.
