Lost TCC lock up when MAF enabled
The long and short is if I take a tune that I have in my truck with the MAF failed at 0hz, turn that on to fail at 13,500 and load it, I loose my TCC lockup in 3rd and 4th gear. I have tried this 3 different times. That is the only change made to that particular tune.
Has anyone had or seen this particular issue? If I go in and force the tcc to lock up with the MAF on, it will in HP Tuners, but it will not lock up on its own as the tune tells it to.
edit- I double checked and yes, for sure, when in SD the trans tables ignore the misfire detection tables. When in MAF then they sanity check against the misfire tables (for some stupid reason). Loosen up your misfire tables and you'll be set.
Edit- Yesterday we had a car come back from the tuners that we did a head/cam/nitrous setup on. Turns out that the tuner had bounced it off the rev limiter really hard on accident and one of the rockers had come off the valve. The bolt was still tight in the head, the rocker had just been bumped off. That misfire obviously wouldn't be intermittent, but the CEL was intermittent. It would go away when you revved it for a second but come back after a couple seconds of idle. It ran like crap, obviously, but the light itself would come on and off even though there's no possible way the misfire was coming and going.
