Koeo map reading ls1
Old Mar 19, 2018 | 02:45 PM
Burken01's Avatar
Default Koeo map reading ls1
I've been having a P0101 pop up lately under acceleration. Regular driving is fine. Anything over 2,500 rpm and it starts to sputter like it's hitting a rev limiter and I get P0101
I noticed my map KPA 93 the other day when the car was off (KOEO) seems a bit off
Thoughts?
Old Mar 20, 2018 | 02:08 PM
LSX Power Tuning's Avatar
We are pretty close to sea level and see 99-100kpa.
Old Mar 20, 2018 | 02:29 PM
01ssreda4's Avatar
mine reads 105
Old Mar 20, 2018 | 05:09 PM
JoeNova's Avatar
Restricted User
P0101 is MAF delta. It means that the actual vs expected is greater than the numbers in MAF delta table. If you have changed your MAF, cam, or something else major, you need a tune. If not, you have a problem somewhere. Consider changing the MAP sensor.
