idle
Old Mar 22, 2018 | 05:13 PM
Dbwallen's Avatar
Default idle
iam new here tks.. 98 trans am 402 storker, built by ven. racing year?, cant get no details from them because iam not org. owner and no info released. org owner died. anyway 6 speed , issue is idle either perfect, to high or to low .fast intake had large crack on under side, fixed with new part ,was plastic.. mas deleate. was programmed in tune,with piece cracked ran fine, new part idle has mine of its own... were do i start to control this issue...ths
Old Mar 23, 2018 | 06:54 AM
JoeNova's Avatar
Restricted User
If it was tuned to work with the cracked intake, and now you have a non-cracked intake and it doesn't run, tune would be what common sense dictates..
Old Mar 23, 2018 | 08:01 AM
Crf450r420's Avatar
Cable throttle you will need to open the hard idle to replace the air not entering through the crack and the rest will likely be okay as long it was into the common area and they didn't offset any cylinders from the others.
