Psi harness and can’t get it to start
Old Apr 14, 2018 | 05:22 PM
Kurtis2short's Avatar
Default Psi harness and can’t get it to start
Alright needing some help guys. I have a lsa on a ly6 I did a psi harness swap with a 411 ecu. The ecu has been worked etc because it it ran with my factory harness but the transmission wouldn’t shift so I bought a psi harness. After I installed the psi harness I can not get this thing to run. It’s like it’s trying to but it just won’t fire and it’ll start for a second then die. Checked all my grounds they are good did a reverse check at the ecu on the 1 and the 40 on both the red and blue all in working order. I’m getting plenty of fuel all my sensors are hooked up any ideas? I believe it’s ignition related but even spraying in quick start there’s nothing. I tested the grounds on the coil packs in working order as is the power to them
Old Apr 14, 2018 | 07:55 PM
brandon6.0's Avatar
Coil harness connected on the correct banks? Correct crank signal for your application? 411 ecm needs a black crank sensor.
Check ign relay on harness. Make sure your ign wire (red one) is hot while key on and cranking.
Old Apr 14, 2018 | 07:57 PM
brandon6.0's Avatar
Are u runnin dbc or dbw? Part # for harness being used? Fuel pump turning on?
Old Apr 21, 2018 | 04:45 PM
Yup coil packs all in working order to the right banks and used their 24x harness I’ve swapped everything needed on the 24x
Old Apr 22, 2018 | 02:43 PM
Darth_V8r's Avatar
Moderator
Vats is off?
