Flip of a switch runs like garbage
Old Apr 22, 2018 | 05:50 PM
ls1guy1968's Avatar
Default Flip of a switch runs like garbage
What's up guys I have a ls6 swap car it has a cam longtubes and other basic bolt ones. I've been running the car for about 500 miles since the tune and ran amazing no problems whatsoever ever. I will post the video but out of nowhere I'm doing a pull shift to third and the car cuts out of no where you'll see. Then continues to cut in and out and in and out as if I was smashing the gas then brake repeatedly. Itll go for 30 seconds then do it again I genuinely have been mind boggled cause it was out of right field. Same thing at idle fine for 30 or so seconds then has a fit and will almost stall. I have fuel pressure I have checked and cleaned all the ground power wires I'm lost any help would be so appreciated also checked for vacuum leaks couldn't find any
Old Apr 24, 2018 | 09:54 AM
black&blu's Avatar
What does the scanner or data log show?
Old Apr 24, 2018 | 01:55 PM
Kawabuggy's Avatar
I'll offer a couple things to look at from the mechanical aspect..
Fuel pump giving up the ghost? Plug in a mechanical gauge, tape it to the windshield so that you can see it while driving. go out and repeat what you are doing when the problem occurs. If the pump is failing, the pressure will fall and the engine will follow. Then as the pump moves a little more gas, the engine will come back, and then repeat.
Does this vehicle have catalytic converters? I've seen where a car with bad cats would not run at HIGH rpm as it would load up and then shut down, and then repeat just like you are saying.
Does the correct guesser get a virtual beer?
Old Apr 29, 2018 | 05:38 PM
rpturbo's Avatar
My vote is fuel pump/fuel pressure.
