12v+ Power only when engine is actually running
Old Apr 25, 2018 | 12:49 PM
toeffer777's Avatar
Default 12v+ Power only when engine is actually running
Does anyone know if there is a circuit that can be used to tell when the vehicle is actually running? I am trying to wire in a safety mechanism to avoid cranking while the engine is running.
Thanks in advance!
Old Apr 25, 2018 | 01:15 PM
Thanks in advance!
Uh, yeah. The ignition circuits are all live, the alternator is charging, the dash instruments should be indicating various conditions. PLUS there are your ears. Take your pick....
Old Apr 25, 2018 | 01:20 PM
toeffer777's Avatar
Ignition circuits are all live when the vehicle is not running but key is in on position, so thats not an option.
Alternator charging could be an option if I found some sort of switch that could engage only over 12.6 volts, but I don't know if something like that exists.
Obviously I can't wire my ear into the car.
Thanks!
