Trouble with 58x to 24x conversion
Old May 5, 2018 | 07:34 AM
RealQuick's Avatar
Default Trouble with 58x to 24x conversion
So I put an LS3 from my camaro into my 2004 gto. I am using the front cam sensor and 58x crank sensor from the camaro.
i am using the LPE TR-002 converter. With key on, the box shows a solid red light. It blinks green when cranking.
When I put a volt meter to crank or cam out, no voltage on any any pin at all (with key on, not cranking).
the car turns over but never fires. Any ideas?
Old May 6, 2018 | 09:28 AM
pantera_efi's Avatar
Default Hall Sensor supply = 5+
Hi RD, the Allegro Hall Sensor MUST have Vcc.
THUS one of the three wires must have a voltage with typical rating by Allegro of 5-24 Volts.
WHEN a tooth passes the signal goes High/Low AS YOU REPORT ?
Lance
Old May 13, 2018 | 01:20 PM
RealQuick's Avatar
On the crank out and cam out coming out of the box the 12v wires each have nothing (three wire setups with 12v, ground, and signal). With key on, I thought Ed the 12v wire should have power.
