General Question
Old May 12, 2018 | 11:49 PM
Monte4ever's Avatar
Default General Question
When switching to a different OS I know you copy and paste general things like your 'VE and spark tables but what about tables like IAC effective area, IAC park position, Startup Airflow and Afterstart enrichment, basically your startup fuel and idle tables. Do you move them over to the new OS or use the tables that's in the new file? I'm sure this would help a lot of people including myself. I've made the switch from 156 OS to the 125 Flex Fuel OS and want to know if i should of used the values in the Flex OS for the IAC and other idle and fueling tables.
