Turbo 5.3 possible tune issues
If you meant -70kPa you have a vacuum leak.
If you truly meant 70kPa, your MAP sensor is probably fucked, or the calibration for it is fucked. If youre MAP says youre boosting 130 and your boost gauge says 10psi, youre probably dumping too much fuel, which explains the power loss and backfiring.
For the op, do key on engine off and see what the map reads. Should be right around 100kpa, if not I'd double check the values you have for the map offset.
Oops I guess I should have kept reading, didn't realize it was already fixed.
So put that in your pipe and smoke it.
