FAST EZ-EFI No Start Issue
Old May 16, 2018 | 03:40 PM
gboisvert's Avatar
Angry FAST EZ-EFI No Start Issue
I have a 1999 Camaro SS with the 6 speed transmission. I purchased and installed the FAST EZ-EFI (part #302000) and XIM (part# 3013122). Before starting the install, I was told by a FAST tech that this kit wound eliminate the factory harness and computer.
Right now the car will not turn over. The starter is installed and hooked up correctly. I think it’s due to all safety switches that were removed with the factory harness (the clutch engagement switch, VATS key sensor, etc.…)
How do I go about solving this problem? Was I misinformed when I was told the factory harness and computer can be eliminated?
Any input is appreciated and thank you in advanced for your help
Old May 16, 2018 | 04:19 PM
Why did you replace a functioning system with one with lesser capabilities?
Old May 19, 2018 | 07:42 AM
gboisvert's Avatar
i also installed new heads and cam. so i went with FAST efi and ecu because they are self tuning.
update - i got the care to start with a bypass switch. haven't been able to take it out for a drive yet but it sounds good at idle the system appears to be working well. i would really like to not have the starter bypass if you have any info?
thank you
