LT4 Gm performance run kit , no throttle
Old May 20, 2018 | 12:37 PM
tinker-27's Avatar
Default LT4 Gm performance run kit , no throttle
hi guys I have fitted a 2018 LT4 engine and t56 magnum , into my m3 bmw , it runs but got no throttle pedal at all it’s the correct Gm pedal supplied with the kit . The throttle blade flicks to open ( around 20% ) on ignition on , then after a couple of seconds it goes back to almost shut , it starts but got no throttle at all , I’m not using the fuel controller or the pressure sensor ( it says on web it will run without this at fixed 60 psi ) , it seems to me it’s in a type of limp home ?? Two fault codes are both fuel sensor related , anynidea people ???? Cheers craig
