melted coil low reference wire
I've been driving it off and on for the last few years and it's been fine, other than troubleshooting cooling issues with my setup. This past Friday i drove it around for a bit and parked it in my garage, came back an hour later to move it and while cranking i noticed smoke from under the dash.... PCM is currently on the passenger floor.
I immediately hopped out and disconnected the battery and started to inspect. Turns out, the Green connector Pin 61 - Purple wire (bank 2 coil - low reference) was melted.
I'm in the process of pulling the harness out to inspect further. Here are pics of the PCM connector as well as the 7 pin coil plug that show damage. I'm pulling the coil sub harness to see how the individual coils look.
Has anyone seen anything like this and what a possible cause might be? I haven't seen anything related in a search, but it seams weird a for a low reference wire.
Any help would be greatly appreciated.
THanks,
Avery
main 0 gauge battery cable to started melted through. It was not touching anything so it looks like it was heat from the #8 cylinder. I’ve made a new cable and have some DeI fire sleeve on the way before I rewire the the harness.
The rest of the car car is apart for a new radiator and fans and possibly an a2w intercooler/water box setup, so it’ll be a while before I can report back on the status
