Need Help with tac module please.
I am new to this site. If I posted this in the wrong place sorry about that. I have already found tons of info already that has helped alot. Anyway I am doing my first LS1 Swap. The car is a 1948 Chevy 2 door Fleetmaster. The ls1 is out of a 2004 corvette Drive by Wire setup. I just got the wiring harness and computer flashed done from the guys at lt1350.com. I finally got the engine to start and it sounds great. However I having problems with the Drive by Wire System. The Throttle body will open just a bit to and allow the engine to idle. The throttle isn't working at all. I was going to convert it to a DBC but the guy at lt1 said that ecu will not support it. The check engine light stays on. ( i got an engine scanner on order should be in tomorrow). So hopefully I can get some codes soon. My question is when I bought the motor it only came with harness and computer it didn't come with the peddle assembly or tac module. I bought the gas peddle and tac module of of ebay and that they claim will work for a 97-04 corvette. When I started looking on line i see there is a bunch of different ones out there. Here is the info that I have on the ecu.
Serv. No. 12586243
*86YFYY924138CM28*
12587908
HDW No. 12583659
Just to verify that I have the right tac module does anyone know where i can find a reference sheet or anything that I can check and make sure that I have the right ecu or peddle assy?
Thanks for all your help..
Serv. No. 12586243
*86YFYY924138CM28*
12587908
HDW No. 12583659
I'm not full bottle on DBW operating systems but I have converter 2005 P59 from DBW to DBC with changing one number in system options.
