dod delete
Old Jul 6, 2018 | 10:08 PM
Indemand1's Avatar
Default dod delete
fresh stage 1 build, cam, dod delete, headers with cat delete into magnaflow exhaust. Will the injectors 1,4,6,7 cut off without a tune in the pcm? only codes are p3401,p3425,p3441,p3449.Both short/long fuel trim banks 1 is at 0%, bank 2 is at -100% both short/long
Old Jul 8, 2018 | 05:54 AM
angeldog1's Avatar
Default Dod
With afm disabled should operate in v8 mode all the time.clear the codes and see.I cranked motor before getting hp tuner and had all those crazy codes one time.p0300 comes up from cam.turn SES off for that one.
Old Jul 10, 2018 | 08:43 AM
Chevy406's Avatar
With the DOD delete hardware your engine will not run on all 8 cylinders until the ECM is recalibrated to disable DOD.
If you have a larger than stock camshaft then you should desensitize the misfire tables to prevent random misfire codes. Many other changes will also be required for the cam change.
