Tuning Issues
Old Aug 19, 2018 | 02:06 PM
RonSSNova's Avatar
I also have a 2000 C5. I learned HPTuners on it 6 years ago. Tuned many cars since.
BTW, 2000 C5 has the two VE table OS
So I’m wondering if your tuner failed the MAF correctly? The MAF takes over after 4000 rpm. A simple test would be to simply unplug it. Start the car twice so the ecu sees the failure.
Fueling switches to the back up VE (the little table) when the MAF is failed.
I personally don’t care for the dual VE OS. So I run mine MAF only and it runs very well. If I could cheat the whole VIN/OS deal I’d put a 2002 OS in it and try SD.
Ron
Old Aug 19, 2018 | 02:12 PM
ddnspider's Avatar
Ron
It gets a bad rep by some but I've always been a big fan of MAF only. Always drives nice and can make just as much power as SD, plus it's super easy to tune.
Old Aug 19, 2018 | 03:28 PM
Darth_V8r's Avatar
Moderator
Ron
The maf was failed AND unplugged in the car I posted about
Old Aug 20, 2018 | 12:21 AM
DarkC5's Avatar
Originally Posted by Gripenfelter
I'll know more tomorrow...I'll be back looking at the car. I will definitely check for vacuum leaks especially on the FAST.
Old Aug 20, 2018 | 02:35 AM
Gripenfelter's Avatar
Take the FAST intake off altogether. Be careful with the brake booster hose on the oil pressure sending unit at the back.
I siliconed the seams on the runners inside the intake as well...overkill I know.
Then I siliconed the back of the intake where you see that white gunk from the previous owner.
Then I put a screw in the MAP mounting hole at the back of the intake (mine had a hole right to the intake).
Other places to look for leaks:
The vacuum hose that hooks up to the back of the intake. Check the hose for breaks too.
The oil catch can of course. Fittings and breather including catch valve.
Restrictions or debris on the MAF screen or clogged air filter.
Old Aug 20, 2018 | 10:12 AM
DarkC5's Avatar
Thanks! I'll go thru that list today!
Old Aug 20, 2018 | 05:39 PM
joecar's Avatar
Are you getting a MAF DTC (you want to see this)...?
Old Aug 23, 2018 | 10:07 AM
DarkC5's Avatar
MAF is completely deleted. We are set up for a full SD tune
Old Aug 23, 2018 | 10:29 AM
Do you have an oil catch can?
Old Aug 23, 2018 | 12:35 PM
joecar's Avatar
Do you know that it is going into SD (i.e. MAF DTC shows up)...?
Old Aug 26, 2018 | 02:49 PM
DarkC5's Avatar
So I changed the Racetronix injectors over to the LS3 injectors, and we completely dumped the tune that was in it and started with a bone stock tune. Suddenly everything started working correctly. The AFR was doing what we commanded it to do, the INJ Duty Cycle %'s were on par again, and the car was responding to every change we made. So far, everything looks like it is sorted out.
Old Aug 26, 2018 | 04:15 PM
  #32
Maybe incorrect injector data?
Old Aug 27, 2018 | 09:03 AM
  #33
ddnspider's Avatar
50/50 injectors or the tune. Glad you're seeing some light at the end of the tunnel.
