Boosted L33 stutter at WOT
It is a gen III, L33, ls1 0411 ecm, SD 80#, twin in tank pumps, 58lb base pressure, boost referenced. All this in a 6 speed 69 nova.
What is happening is a few things:
There is a stutter at about 4K rpm that you can almost see in the RPM curve. What it does correlate to is the injector pulse jumps up and not sure why.
When I run the car at 43# base fuel pressure, I do not see the issue as much but I am going to want the higher base pressure since I will be going to E85 soon and do not want to jump to bigger injectors to make my power goals.
For the injector data, I have seen there are at least 3 different sets of injector data out there so I have the one loaded up that seems to work best.
Any idea as to what it could be and any thoughts on how the log looks?
thank you
Did just pick up some new plugs at lunch today, will throw them in the car tonight and make a pull. I will gap the new plugs to .024/.025
10.2AFR with less than 8psi boost and 10 degrees timing will never burn.
use the VE table to lean out the fuel back to 11.50-11.80 at least. don't be scared to add a little timing as you're on very little boost. that will also help burn the fuel and clean up the pull. your VE values from around 1200-3200 RPM through the transition into boost are huge.
see attached examples
