Tuning with a turbo - Log included
Old Aug 23, 2018 | 12:06 PM
Monello's Avatar
Default Tuning with a turbo - Log included
Fixed a lot of items that were causing the car to run rough and wanted to see how everything looks like with the items resolved. Previously the car was having issues starting after driving a bit and also had a massive exhaust leak at the driver side turbo manifold.
After fixing the exhaust link due to cracked weld and installing the new Racetronix 255 pump and hot wire kit all seems to be running well.
I grabbed a few logs while driving to work today. I did click the button to reset the LTFT before starting the log. Wideband is showing around 14.9/15 at idle. Did not go into WOT/Boost at all on the drive to work.
Last bin was given to me by Frost when he was assisting 8+ years ago. He had made a few changes for the FLT trans with 3200 stall.
File Type: hpl
File Type: hpl
File Type: hpt
Last edited by Monello; Aug 23, 2018 at 12:35 PM. Reason: Updated info regarding trans.
Old Aug 23, 2018 | 12:42 PM
ddnspider's Avatar
Your WOT AFR could be leaned out a bit, it looks like your EQ is set to 1.329. Some power to be had by upping it to 11.2-11.4 depending on boost level. You run more timing than I do, but if its not knocking thats good.
Old Aug 23, 2018 | 04:24 PM
truckdoug's Avatar
turbo with a maf? what is this witchery!
Old Aug 23, 2018 | 05:26 PM
LSX Power Tuning's Avatar
I recommend going to the 2 bar OS and adding a 2 bar map sensor.
Old Aug 23, 2018 | 05:46 PM
ddnspider's Avatar
Ain't nothing wrong with a turbo and a MAF.....can make big HP if you know what you're doing.
Old Aug 23, 2018 | 05:51 PM
A correctly dialed in MAF will keep AFR's more precise than SD setups, in my opinion.
Old Aug 23, 2018 | 07:34 PM
ddnspider's Avatar
True statement.
Old Aug 23, 2018 | 10:41 PM
truckdoug's Avatar
you know what we do with witches round here. we tie them to a 4L60e and if they float, they're a witch
Old Aug 23, 2018 | 10:45 PM
Dimeomboost's Avatar
4l60e Are turds and turds float so I say we burn em at the stake and let the god of tuning sort them out
Old Aug 24, 2018 | 01:17 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
True statement.
That is only true to the extent that you properly tuned under driving conditions. An SD tune can be more accurate than a MAF tune, but only if tuned under the conditions you drive in. This is the difference between a short drive tuning a MAF vs thousands of hours of SD tuning, so your idea is usually correct. That being said, even a good Alpha N tune will usually get the job done, so this is a matter of splitting hairs.
Old Aug 24, 2018 | 06:38 AM
ddnspider's Avatar
I must be an alien then.....boost with a 4l60e AND a MAF.... blasphemy!!!
Old Aug 24, 2018 | 09:58 AM
Monello's Avatar
Looking to only boost up to 8psi. Is there a real benefit to going 2 bar/SD? Or can the 1 bar with MAF handle this setup Thoughts?
Old Aug 24, 2018 | 10:38 AM
Luke19901's Avatar
I personally do all turbo cars in SD. I struggle to dial in the very rapid fueling transition required during spool up and coming on boost and the associated drastic dynamic air mass changes with a MAF. I find measuring air mass via flow in an intercooler pipe to be a struggle to dial in compared to a RPM vs MAP VE table.
personally I find SD with a turbo car far easier to the point I wont do one with a MAF, or more so wont do one with a MAF and actually use the MAF.
Old Aug 24, 2018 | 04:49 PM
ddnspider's Avatar
Stock MAF without any trickery is good to between 550-600whp depending on the setup and drivetrain. So yes 8 Psi will work with a MAF.
