Injector rating for boost referenced FPR
Old Aug 24, 2018 | 06:20 PM
The Fugitive's Avatar
Default Injector rating for boost referenced FPR
When tuning the injectors with a boost reference fuel pressure regulator and a return system do I use what the injector is rated for (@ 43.5psi) or do I use the adjusted value for the fuel pressure (58psi)? For example with the SD 60lbs injectors (which is actually more than 60 mine are 64's) do I use 60 or 64 across the board or do I use 69.3 or 73.9? I am trying to figure out the offset vs voltage for the injectors but I don't want to stumble on the 1st step. Any help would be appreciated, thanks
Old Aug 24, 2018 | 10:24 PM
truckdoug's Avatar
use the rated flow number for the actual fuel pressure you will use
Old Aug 25, 2018 | 01:14 PM
Thanks I will be going with 73.9.
