Sensors needed to make ls1 run
Do I need MAF sensor iat sensor ever to make the engine run ?
What sensors are definitely NEEDED to make engine run?
can I still get obd readings without sensors ??
please help I have the harness stripped down & depinned following lt1swap pinout sheet & help from here
Sensors needed for engine to run correctly are Cam and Crank sensor, IAT,IAC, MAF, Water Temperature, MAP, TPS, O2 Sensor, Not 100% sure if you need Oil pressure or not and you'll probably want to run Knock Sensors.
i depinned iat. Iac & MAF already I have to figure out how to get them ran back on smh
